8 qt cell up an running | 30 comments (30 topical, 0 editorial)
Re: 8 qt cell up an running (3.00 / 0) (#2)
by DamonHD (d@hd.org) on Thu May 8th, 2008 at 07:18:07 AM MST
Or moonshine to run the driver?  B^>
I too am lost on what you're doing.
Re: 8 qt cell up an running (3.00 / 0) (#3)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Thu May 8th, 2008 at 08:12:04 AM MST
Damon;
 It's called HHO or hydrogen / brown's gas into intake for gas engines. It makes use of the on board spare power aka battery or similar PTO.
It's a well known addon for gas engines to get a much better burn in the cylinders with extra milage as well. Some have doc showing 30% increase at initial usage.
NOT normally pure H2 since it's using the cracked H2 and O to make the in-cylinder burn much more complete.
The O give the gas more oxygen for more complete burn. The hydrogen gives it a bit more fuel to burn.
NOT to be confused with the OU stuff, this has been proved and works.
JUST becareful there high enough current involved to do in someone who isn't careful.
Tecker: good to see the larger container is working out:-)
Keep us up to date. some may need a more complete write up and more pics:-)
Re: 8 qt cell up an running (3.00 / 0) (#4)
by jimjjnn (jimjjnn at yahoo dot com) on Thu May 8th, 2008 at 08:13:46 AM MST
It looks to me that he is making "Brown's" gas from water to help his vehicle to save fuel. I believe it will increase power as well. Not real sure tho
Jim Denver,CO
Re: 8 qt cell up an running (3.00 / 0) (#15)
by tecker on Thu May 8th, 2008 at 10:21:45 PM MST
 There's no doubt ist's browns gas.
Re: 8 qt cell up an running (3.00 / 0) (#14)
by tecker on Thu May 8th, 2008 at 10:20:26 PM MST
 Soops on
Re: 8 qt cell up an running (3.00 / 0) (#18)
by DamonHD (d@hd.org) on Fri May 9th, 2008 at 02:00:34 AM MST
Now soup I do understand the merits of!
