8 qt cell up an running | 30 comments (30 topical, editorial)
Re: 8 qt cell up an running (3.00 / 0) (#21)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Fri May 9th, 2008 at 07:34:02 AM MST
zapmk;
  HHO is registered? I know there a group in Africa there is HHO Africa, but didn't think it was using the all caps version. Plus the HO trains.
 You are correct the hydroxy is on the Yahoo groups, there's a bio-D groups here in St. Louis that was looking into using this to help with a more complete burn , but not looking so good.
In order to use this process with Diesel engines, there's discussion of modifying the heads to install spark plugs.
NOT my idea of easy.
Re: 8 qt cell up an running (3.00 / 0) (#23)
by zapmk on Fri May 9th, 2008 at 08:31:23 AM MST
Here you go,
http://tarr.uspto.gov/servlet/tarr?regser=serial&entry=77180550
http://tarr.uspto.gov/servlet/tarr?regser=serial&entry=77180591
Some of the Yahoo groups even Ban guys from the forums just for using the 3 letter word in caps :>0
Re: 8 qt cell up an running (3.00 / 0) (#24)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Fri May 9th, 2008 at 10:21:20 AM MST
Thanks for the link. Not yet allowed, there seems to be an opposing claim.
BUT to be on the safe side will use hydroxy.
If they want to sue me over the use , then so be it.
Will give the new media something else to clammer about :--)
8 qt cell up an running | 30 comments (30 topical, 0 editorial)
