Damon;
It's called HHO or hydrogen / brown's gas into intake for gas engines. It makes use of the on board spare power aka battery or similar PTO.
It's a well known addon for gas engines to get a much better burn in the cylinders with extra milage as well. Some have doc showing 30% increase at initial usage.
NOT normally pure H2 since it's using the cracked H2 and O to make the in-cylinder burn much more complete.
The O give the gas more oxygen for more complete burn. The hydrogen gives it a bit more fuel to burn.
NOT to be confused with the OU stuff, this has been proved and works.
JUST becareful there high enough current involved to do in someone who isn't careful.
Tecker: good to see the larger container is working out:-)
Keep us up to date. some may need a more complete write up and more pics:-)
