May I charge the battery directly? | 14 comments (14 topical, editorial)
Re: May I charge the battery directly? (3.00 / 0) (#3)
by ZooT on Thu May 8th, 2008 at 11:48:36 AM MST
The battery should hold the entire system down to it's current voltage.....
You hook up your 50 volt turbine to the battery and the voltage should drop to the current but slowly climbing battery voltage....
That's where the dump controller comes in, in that when the battery voltage gets too high, it's dumps the excess to keep it down to a safe level
Re: May I charge the battery directly? (3.00 / 0) (#4)
by john2008 on Thu May 8th, 2008 at 11:55:20 AM MST
 what happen to one battery(12v) that is charged by two batteries(24v)?does it show 12v or 24v when you measured it by a multimeter? it does not make a sense if it is 12v?(but you might right,just wondering.)
Re: May I charge the battery directly? (3.00 / 0) (#9)
by ghurd on Thu May 8th, 2008 at 06:02:57 PM MST
He  IS  right.
One of the batteries might explode, if the wires or terminals didn't melt off first.
You need to read and understand some of this stuff before someone gets hurt.
Or worse.
Start with Ohm's Law. Then Watt's Law. Then Kirchoff's Law.
If this is some kind of a joke, it is not funny.
Re: May I charge the battery directly? (3.00 / 0) (#10)
by TomW on Thu May 8th, 2008 at 08:26:29 PM MST
G-;
I think a lot of folks do not "get" the kind of instantaneous, violence a large [or even small] battery bank can deliver faster than you can even register anything happened.
In my misspent youth I was working on a forklift battery and accidentally shorted the bus bars and had the dubious honor of seeing lead terminals melt and flow away from the connections at light speed amid a thunderstorm of sparks and crackling noise. All took  like a half a microsecond. Luckily I was wearing long sleeves a hat and sunglasses and no battery exploded just the sparks smoke and molten lead spewing around.
Oh, yeah the wrench was pretty much fused to the bus bars. Needless to say it destroyed the battery by melting or mostly melting off the terminals on all of them. Was not my finest moment but I learned to respect batteries from it.
Just something to think about before diving into the handling of batteries.
You Mileage May Vary.
May I charge the battery directly? | 14 comments (14 topical, 0 editorial)
