Blade weight | 13 comments (13 topical, 0 editorial)
Re: Blade weight (3.00 / 0) (#5)
by kurt on Fri May 9th, 2008 at 06:23:37 AM MST
clflyguy, image posting rules do apply to you. please keep your images under 640 x 480 pixels and under 150 KB. i removed your comment because it was the only way to remove your over sized image.
http://www.reresource.org/
IRC
Re: Blade weight (3.00 / 0) (#6)
by clflyguy (sidney.raiford@gmail.com) on Fri May 9th, 2008 at 06:26:17 AM MST
Sorry Kurt- forgot to check before sending- will dial it down and re-send
Re: Blade weight (3.00 / 0) (#9)
by JW1111 on Fri May 9th, 2008 at 08:17:31 AM MST
That picture is very helpful.  It is almost spot on.  Except for the 3/8" off set between the tip and root.  I can see you did this for more twist.  I did not do this, I ran my leading edge line parellel with the tube, but I still have nice twist, just not as much as that.  I was able to get a nice foil, and then sanded it flat out the end.  I will post a picture if I can figure out how.
