Filling water heat storage tank with rocks | 16 comments (16 topical, editorial)
Re: Filling water heat storage tank with rocks (3.00 / 0) (#14)
by TomW on Mon May 12th, 2008 at 12:00:58 PM MST
Scott;
I kind of figured it was an in ground insulated tank. The rubber sheet is the key there. Must be cheaper than steel and never rots. Been looking at poly tanks for rainwater capture for backup and garden / tree watering. They are pretty dear and not suitable for anything hot. I want gravity feed on the outflow so in ground not an option for me for the rainwater gathering.
Thanks for the feedback.
Contact: IRC
Re: Filling water heat storage tank with rocks (3.00 / 0) (#15)
by scottsAI (user name at eml dot cc) on Tue May 13th, 2008 at 12:25:53 AM MST
TomW,
This is where I come to learn, and help when I can.
Why the gravity feed?
How about two tanks, upper is small for daily flow.
Lower for the mas storage. Pump to upper tank when you have the power.
Ebay plastic potable water tank 2500 gal for $1000 w/ship.
I will use one or two for potable water. Rain water.
EPDM Liner for the heating tanks. What did you want to pay?
In ground was cheaper, to make an above ground tank, surely it will cost more than the pump?
Consider an above ground pool as a storage tank, used pools are cheap.
Liners are not too costly or use EPDM liner for heating.
Pump, I am sure you have looked at RV pumps?
Ebay: 4.7gpm RV pump for $50 w/ship. Works great on my well.
Not sure how long it will last, couple friends have been using them all summer long for years, still working.
Have fun,
Scott.
Re: Filling water heat storage tank with rocks (3.00 / 0) (#16)
by TomW on Tue May 13th, 2008 at 07:26:26 AM MST
Scott;
Gravity feed was based on simplicity. the location will be away from power sources and mostly for garden / tree watering. If it requires much more than a faucet the better half will consider it "too complicated". If you are married you will understand these type limits.
Nothing is ever as simple as it seems.
The cost is not such a limiting factor but keeping it down leaves more for other stuff.
Right now this is a wish list project so I have not done any in depth research.
When it gets closer to an actual project I will look closer at options
Tom.
Contact: IRC
Filling water heat storage tank with rocks | 16 comments (16 topical, 0 editorial)
