Filling water heat storage tank with rocks | 16 comments (16 topical, editorial)
Re: Filling water heat storage tank with rocks (3.00 / 0) (#16)
by TomW on Tue May 13th, 2008 at 07:26:26 AM MST
Scott;
Gravity feed was based on simplicity. the location will be away from power sources and mostly for garden / tree watering. If it requires much more than a faucet the better half will consider it "too complicated". If you are married you will understand these type limits.
Nothing is ever as simple as it seems.
The cost is not such a limiting factor but keeping it down leaves more for other stuff.
Right now this is a wish list project so I have not done any in depth research.
When it gets closer to an actual project I will look closer at options
Thanks for the feedback.
Tom.
Contact: IRC
Filling water heat storage tank with rocks | 16 comments (16 topical, 0 editorial)
