I believe you will find that per equal volume, Iron will do better than water but of course the weight becomes quite large. But though, water is free and everything else isn't, at least in the metals area... That's why water is so tough to beat... .....Bill [ Parent ]
Iron is .866 of water. May be 7.8 times more dense, CP only 0.11 Copper is even more dense at 8.96, yet CP is 0.09 = 0.806. Not too many things better than water, yet if price is no object it can be found.
Have fun, Scott.[ Parent ]
Those numbers are probably right... I thought Iron had tipped the scale to the other side but perhaps not. Most of the research and products that will do better than water are all of a phase change nature. You can get a large heat release at a particular temperature and some sensible heat capacity above and below the transition point as well. But of course, the cost is a different matter..... .....Bill [ Parent ]
Care to share the cheap tank construction method? Since you mentioned it, I am curious how you did it.
Contact: IRC
The steel tanks were a show stopper to my cost targets, spend a long time finding: http://www.builditsolar.com/Projects/SpaceHeating/SolarShed/Tank/SizingTank.htm Tank Cost: http://www.builditsolar.com/Projects/SpaceHeating/SolarShed/Tank/Cost.htm
Plan to put tank under back porch (over sized), in ground with insulation.
EPDM liner http://en.wikipedia.org/wiki/EPDM_rubber Good to 150 deg C, great for solar heating projects!
Unfortunately I did not get to build the tank, was laid off before I got the property to build my Net Zero Energy Home design.
What do you think?
I kind of figured it was an in ground insulated tank. The rubber sheet is the key there. Must be cheaper than steel and never rots. Been looking at poly tanks for rainwater capture for backup and garden / tree watering. They are pretty dear and not suitable for anything hot. I want gravity feed on the outflow so in ground not an option for me for the rainwater gathering.
Thanks for the feedback.
This is where I come to learn, and help when I can.
Why the gravity feed? How about two tanks, upper is small for daily flow. Lower for the mas storage. Pump to upper tank when you have the power. Ebay plastic potable water tank 2500 gal for $1000 w/ship. I will use one or two for potable water. Rain water. EPDM Liner for the heating tanks. What did you want to pay? In ground was cheaper, to make an above ground tank, surely it will cost more than the pump?
Consider an above ground pool as a storage tank, used pools are cheap. Liners are not too costly or use EPDM liner for heating.
Pump, I am sure you have looked at RV pumps? Ebay: 4.7gpm RV pump for $50 w/ship. Works great on my well. Not sure how long it will last, couple friends have been using them all summer long for years, still working.
Gravity feed was based on simplicity. the location will be away from power sources and mostly for garden / tree watering. If it requires much more than a faucet the better half will consider it "too complicated". If you are married you will understand these type limits.
Nothing is ever as simple as it seems.
The cost is not such a limiting factor but keeping it down leaves more for other stuff.
Right now this is a wish list project so I have not done any in depth research.
When it gets closer to an actual project I will look closer at options
Tom.
