Zero offset op-amp or not! | 12 comments (12 topical, editorial)
Re: Zero offset op-amp or not! (3.00 / 0) (#10)
by scottsAI (user name at eml dot cc) on Sat Jun 14th, 2008 at 09:35:37 AM MST
Monitoring equipment should draw as little power as possible from your battery.
I like altosack (Dave's) post #5 best.
Looked up AVR ATiny861, like he says has 20x gain diff amp built in.
Look over the Data Sheets states in section 19.8.3 or page 153.
Set as bipolar mode, discover direction of input, then set up the differential channels as unipolar with the correct direction for the full range.
As mentioned; over sampling effective resolution enhancement can be achieved.
4 times over sampled get one extra bit. Search on ENOB for more info.
Sample 4 times, average result, now resolution is one bit more. 16X = 2 bits etc.
Remember resolution and accuracy are NOT connected in an ADC. The accuracy remains fixed, just have more bits to play with!
I drew up the opamp, but after reading Dave's post figured it was the best way to go.
Have fun,
Scott.
Re: Zero offset op-amp or not! (3.00 / 0) (#11)
by frackers (g8ecj at *nospam* gilks dot org) on Sun Jun 15th, 2008 at 03:36:36 AM MST
One major issue is that I have tubes full of AVRs that run with the emulator I have - the newer parts don't :-(
Concerning the current draw - if I have to worry about 10mA taken from a 500amp/hr battery bank I'm in the wrong game!! Check out my diaries on the way I'm going to be using this system - storage as such is not really a requirement.
Guess I'm going for a floating supply on the monitor after all...
Re: Zero offset op-amp or not! (3.00 / 0) (#12)
by scottsAI (user name at eml dot cc) on Sun Jun 15th, 2008 at 09:42:29 AM MST
you OK with using an opamp? which ones are easy to get for you?
Zero offset op-amp or not! | 12 comments (12 topical, 0 editorial)
