Zero offset op-amp or not! | 12 comments (12 topical, editorial)
Re: Zero offset op-amp or not! (3.00 / 0) (#11)
by frackers (g8ecj at *nospam* gilks dot org) on Sun Jun 15th, 2008 at 03:36:36 AM MST
One major issue is that I have tubes full of AVRs that run with the emulator I have - the newer parts don't :-(
Concerning the current draw - if I have to worry about 10mA taken from a 500amp/hr battery bank I'm in the wrong game!! Check out my diaries on the way I'm going to be using this system - storage as such is not really a requirement.
Guess I'm going for a floating supply on the monitor after all...
Re: Zero offset op-amp or not! (3.00 / 0) (#12)
by scottsAI (user name at eml dot cc) on Sun Jun 15th, 2008 at 09:42:29 AM MST
you OK with using an opamp? which ones are easy to get for you?
Zero offset op-amp or not! | 12 comments (12 topical, 0 editorial)
