Ram Pump Problem | 14 comments (14 topical, editorial)
Re: Ram Pump Problem (3.00 / 0) (#9)
by Flux on Sun Jun 15th, 2008 at 02:55:08 PM MST
Not sure where you got this data. you will never get a ram to keep running with only 1ft difference between drive and delivery head. With low heads you will have to have careful control of the waste valve to get it to run with less than 3:1. At higher heads you may manage 3:1 with simpler valves.
With non adjustable valves you may need 7:1 to keep it running at heads below 4ft drive.
Ratios of up to 20:1 are common and the limit is way over this at low efficiency.
Re: Ram Pump Problem (3.00 / 0) (#10)
by scottsAI (user name at eml dot cc) on Sun Jun 15th, 2008 at 08:45:52 PM MST
Thanks Flux,
Not sure where I got the 7x from, read about it some where. Remembered it as practical, like you said higher ratio are not efficient?-)
I researched it and see 20x and higher is possible! Very cool. Thanks.
1 foot higher on the output, why do anything less?
http://www.clemson.edu/irrig/equip/ram.htm
Paragraph labeled: Valve Operation Descriptions
The swing check valve (part 4 - also known as the impetus valve) can be adjusted to vary the length of stroke (please note that maximum flow and pressure head will be achieved with this valve positioned vertically, with the opening facing up). Turn the valve on the threads until the pin in the clapper hinge of the valve is in line with the pipe (instead of perpendicular to it). Then move the tee the valve is attached to slightly away from vertical, making sure the clapper hinge in the swing check is toward the top of the valve as you do this. The larger the angle from vertical, the shorter the stroke period (and the less potential pressure, since the water will not reach as high a velocity before shutting the valve). For maximum flow and pressure valve #4 should be in a vertical position (the outlet pointed straight up).
Therefore just over 1x is possible too!
Does this agree with you?
Have fun,
Scott.
Re: Ram Pump Problem (3.00 / 0) (#11)
by Flux on Mon Jun 16th, 2008 at 01:50:32 AM MST
Interesting. I have never tried any form of swinging clack valve so can't comment.
If you can get down to 1ft above drive head it could be very useful in some applications. I have had only limited success working with drive heads below 18" but if you could get it reliably down to 1ft drive the ratio would then be 2:1 and that is possible with care.
The standing wave needed to reverse the flow in the drive pipe needs to come from doing work on the delivery side, it may be that using rather inappropriate delivery valves will provide this with lower ratios, so part of this success may also be related to the delivery valve chosen.
Ram Pump Problem | 14 comments (14 topical, 0 editorial)
