Tower: Experience on what NOT to do | 11 comments (11 topical, editorial)
Re: Tower: Experience on what NOT to do (3.00 / 0) (#2)
by joestue on Sat Jun 14th, 2008 at 06:26:58 PM MST
If you can get rebar cheap, 3/8th inch should work, i would weld together my own triangular radio type tower, rather than buy more angle iron to reinforce the tower.
Re: Tower: Experience on what NOT to do (3.00 / 0) (#4)
by DanB (danb@*no spam*otherpower.com) on Mon Jun 16th, 2008 at 04:29:31 PM MST
I think rebar is pretty scary stuff - expecially in a tower application with fatigue.  its about the lowest grade steel, it's very quick to fatigue and break.  Perhaps OK for the reinforcement inside a lattice tower, I have seen that done and time will tell how it works out (codes are pretty relaxed in Nicaragua).  But I would not build a tower from re-bar.  Just my opinion!  Stuff I have made from it often broke over time.
Re: Tower: Experience on what NOT to do (3.00 / 0) (#6)
by joestue on Mon Jun 16th, 2008 at 05:31:13 PM MST
thats exactly what i meant, using the two pipes he already has, just buy a third.
place then 6-9 inches apart. Mentioned rebar because it is often free..
Tower: Experience on what NOT to do | 11 comments (11 topical, 0 editorial)
