buss bars | 5 comments (5 topical, editorial)
Re: buss bars (3.00 / 0) (#2)
by frackers (g8ecj at *nospam* gilks dot org) on Thu Jun 19th, 2008 at 05:58:21 PM MST
I managed to get hold of some thick copper sheet (about 14awg) which when cut into strips provides a higher cross sectional area than pipe. For insulation, I used heat-shrink sleeving, 2 layers (and make sure the copper has no sharp edges otherwise the sleeving will tear).
Works well and I would think that a 1" wide strip will be good for up to 100 amps.
buss bars | 5 comments (5 topical, 0 editorial)
