transformer type/identification ? | 11 comments (11 topical, editorial)
Re: transformer type/identification ? (3.00 / 0) (#5)
by bob g on Sat Jun 21st, 2008 at 09:57:02 PM MST
i don't think i have ever seen a 40# transformer (dry type) rated at only 1 kva?
i do however have another set of three 120/24 volt units rated at 1.25kva
and they are about 1/3 the size of these transformers i am in reference to.
evidently there is quite a span on these units in size/weight vs kva?
bob g
Re: transformer type/identification ? (3.00 / 0) (#8)
by FuddyDuddy (long.shanks@comcast.net) on Sun Jun 22nd, 2008 at 11:13:33 AM MST
These units are about 7" square and 6" high. I suspect the size/weight is due to the fact that the insulation is much thicker than lower voltage units. They are built to run across either a 480vac or 240vac primary and supply 120vac for industrial control systems, thus are quite heavy.
FuddyDuddy
Re: transformer type/identification ? (3.00 / 0) (#9)
by bob g on Mon Jun 23rd, 2008 at 07:25:57 PM MST
Fuddy:
well i guess i will have to get around to doing a plug in test and see what it is i have.
also my lift calibration might be significantly off, these might be a bunch heavier than 20 lbs each,, it isn't like i lift stuff daily that i am aware of the weight like i would be if i were a UPS or FEDEX delivery guy :)
i just can't imagine that these would be much less than 2kva each, but we shall see i guess.
i don't really need them to be 2kva, i would be ok with them being 1.5kva each
for my needs and even then they would not be at that load rating for very long.
the majority of the time they would probably be well under 1 kva each.
one just doesn't see these things with enough regularity around here to have a frame of reference.
with scrap prices going to the sky, there will be even less of them laying around.
i got these just hours before they went into the scrap rolloff dumpster for recycling.
bob g
Re: transformer type/identification ? (3.00 / 0) (#10)
by FishbonzWV on Tue Jun 24th, 2008 at 04:08:45 PM MST
Bob,
I've got two 3ph xformers, different sizes, with power ratings on them. Both are 208v delta inputs and 32v wye outputs. The coils are as you described, 15 guage wire primary and 1/8" x 1/4" square wire secondary.
I weighed them both to give you some numbers to crunch.
Smaller one is 52 lbs with an output of 65 Amps
Larger one is 77 lbs  with an output of 107 Amps.
Hope this helps
Fishbonz
Re: transformer type/identification ? (3.00 / 0) (#11)
by bob g on Tue Jun 24th, 2008 at 07:15:22 PM MST
fishbonzwv:
thanks for the info
i need to get a scale, i may be far too light on my estimation
i have been installing and reinstalling a 70lb pto on a truck
for the last 2 weeks (ugly story) and never realized that it was 70lbs
till i looked at the shipping slip today!
so my estimate of 20lbs on these transformers may be off a bit
they might be 30 or 40lbs each,, i dunno :)
my calibration of weight is getting a bit off as i age i guess.
some days 10lbs feels like a hundred, other days who knows
one thing for sure,, a hundred lbs is always too friggin heavy for me
to want to wrangle with.
thanks guys
bob g
transformer type/identification ? | 11 comments (11 topical, 0 editorial)
