software | 24 comments (24 topical, editorial)
Re: software (3.00 / 0) (#18)
by david williams on Tue Aug 26th, 2008 at 01:31:21 PM MST
Thanks Bill. It looks good. Strange, to my eyes, but good.
Re: software (3.00 / 0) (#19)
by bills on Wed Sep 3rd, 2008 at 07:20:50 AM MST
Thanks David, It looks like a bunch of the symbols have disappeared from the code in the prints there should be backslash n for a newline when I posted it they seem to have been stripped. I'll have to look into this.
I will try to re-post a corrected copy.
Bill
Re: software (3.00 / 0) (#20)
by bills on Wed Sep 3rd, 2008 at 07:26:56 AM MST
#!/usr/bin/perl
use strict;
use warnings;
use Math::Trig;
# SunAlign.pl (Version for Perl)
# Calculates position of sun in sky, as azimuth (compass bearing
# measured clockwise from True North) and angle of elevation, as
# seen from any place on earth, on any date and any time.
# Also calculates alignment of a heliostat mirror.
# David Williams
# P.O. Box 48512
# 3605 Lakeshore Blvd. West
# Toronto, Ontario. M8W 4Y6
# Canada
# Initially dated 2007 Jul 07 (Basic version)
# This version 2008 August 08
# Perl version ported by William K Stewart, 2008 Aug 15
# gmail username = lc([first initial][middle initial][lastname])
# All angles in radians except in i/o routines DegIn and DegOut
my $PY = 3.1415926536;           # "PI" not assignable in some BASICs
my $DR = 180/$PY;                # degree / radian factor
my $W  = 2 * $PY/365;            # earth's mean orbital angular speed in radians/day
my $WR = $PY/12;                 # earth's speed of rotation relative to sun (radians/hour)
my $C  = -23.45/$DR;             # reverse angle of earth's axial tilt in radians
my $ST = sin($C);                # sine of reverse tilt
my $CT = cos($C);                # cosine of reverse tilt
my $E2 = 2 * 0.0167;             # twice earth's orbital eccentricity
my $SN = 10 * $W;                # 10 days from December solstice to New Year (Jan 1)
my $SP = 12 * $W;                # 12 days from December solstice to perihelion
my($LT, $LG, $tAZ, $tEL) = ();
while(1) {
   my $S;
    do{
        print "1. Calculate sun's position\n";
        print "2. Calculate mirror orientation\n";
        print "3. Calculate both\n";
        print "4. Quit program\n\n";
        print "Which? (1 - 4): ";
        $S = <STDIN>;
        chomp $S;
    } while(!($S >= 1 && $S <= 4));
    print "\nYou selected: $S\n";
    last if $S == 4;
    print "\nUse negative numbers for directions opposite to those shown.\n\n";
    DegIn ("Observer's latitude (degrees North)", \$LT);
    DegIn ("Observer's longitude (degrees East)", \$LG);
    my $TZN;
    do {
        print "Time Zone (+- hours from GMT/UT): ";
        $TZN = <STDIN>;
        chomp $TZN;
    } while($TZN !~ /^-?\d+$/);
    my $time;
    do {
        print "Time (HH,MM) (24-hr format): ";
        $time = <STDIN>;
        chomp $time;
    } while($time !~ /^\d+,\d+$/);
    my($HR, $MIN) = split(",", $time);
    my $date;
    do {
        print "Date (M#,D#): ";
        $date = <STDIN>;
        chomp $date;
    } while($date !~ /^\d+,\d+$/);
    my($Mth, $Day) = split(",", $date);
    print "\n";
 # co-latitude
    my $CL = $PY/2 - $LT;
    #day of year (D = 0 on Jan 1)
    my $D = (30.6 * (($Mth + 9) % 12) + 58.5 + $Day) % 365;
    # orbit angle since solstice at mean speed
    my $A = $W * $D + $SN;
    # angle with correction for eccentricity
    my $B = $A + $E2 * sin($A - $SP);
    $C = ($A - atan2(tan($B),$CT))/$PY;
    my $tmp = $C + .5;
    my $tmp1 = $C - 1;
    # solar longitude relative to mean position
    #my $SL = $PY * ($C - INT($C + .5));
    my $SL = $PY * ($C - int($C + .5));
    $C = $ST * cos($B);
    # solar declination (latitude)
    my $DC = atan2($C, sqrt(1 - $C * $C));
    # longitude difference
    my $LD = ($HR - $TZN + $MIN / 60) * $WR + $SL + $LG;
    # polar axis (perpend'r to azimuth plane)
    my($sX, $sY, $sZ);
    P2C($LD, $DC, \$sX, \$sY, \$sZ);
    # horizontal axis
    my($sAZ, $sEL);
    C2P($sY, $sZ, $sX, \$sAZ, \$sEL);
    # rotate by co-latitude
    P2C($sAZ - $CL, $sEL, \$sY, \$sZ, \$sX);
    if($sZ < 0) {
       print "\n\nSun Below Horizon\n\n";
       print "New Calculation\n";
       next;
 if($S != 2) {
        # calculate and display sun's position
        # vertical axis
        C2P($sX, $sY, $sZ, \$sAZ, \$sEL);
        DegOut("Sun's azimuth: ", \$sAZ);
        DegOut("Sun's elevation: ", \$sEL);
        print "\n";
    if($S > 1) {
        # calculate and display mirror orientation
        print "For target direction of light reflected from mirror:\n";
        DegIn ("Azimuth of target direction (degrees)", \$tAZ);
        DegIn ("Elevation of target direction (degrees)", \$tEL);
        print "\n";
        my($tX, $tY, $tZ);
        # target vector X,Y,Z
        P2C($tAZ, $tEL, \$tX, \$tY, \$tZ);
        my($mAZ, $mEL);
        # angle bisection by vector addition
        C2P($sX + $tX, $sY + $tY, $sZ + $tZ, \$mAZ, \$mEL);
        print "Mirror aim direction (perpendicular to surface):\n";
        DegOut("Azimuth: ", \$mAZ);
        DegOut("Elevation: ", \$mEL);
        print "\n";
sub Ang {
    # calculates angle from positive X axis to vector to (X,Y)
    my($X, $Y) = @_;
    my $angle;
    my $val = sgn($X);
    if($val == 1) {
        $angle = atan($Y/$X);
    elsif($val == -1) {
        $angle = atan($Y/$X) + $PY;
    else {
        $angle = sgn($Y) * $PY/2;
    return $angle;
sub C2P {
    # Cartesian to Polar. Convert from X,Y,Z to AZ,EL
    my($X, $Y, $Z, $AZ, $EL) = @_;
    $$EL = Ang(sqrt($X * $X + $Y * $Y), $Z);
    my $A = Ang($Y, $X);
    if($A < $PY) {
        $$AZ = $A + $PY;
    else {
        $$AZ = $A - $PY;
    return;
sub DegIn {
    # Input angle in degrees and convert to radians
    my($P, $X) = @_;
    my $N;
    do {
        print $P,": ";
        $N = <STDIN>;
        chomp $N;
    } while($N !~ /^-?\d+$/);
    $$X = $N/$DR;
    return;
sub DegOut {
    # converts radians to degrees, rounds to nearest 0.1, and prints
    my($P, $X) = @_;
    #my $S = LTRIM(STR(INT(10 * abs($$X * $DR) + .5)));
    my $S = 10 * abs($$X * $DR);
    $S = round($S);
    $S = 0 if($S eq "3600");
   $S = "0" . $S if(length($S) == 1);
    if($$X < 0) {
        if($S) {
            $S = "-" . $S;
    $S =~ s/(.+)(.)$/$1\.$2/;
    print "$P $S degrees\n";
    return;
sub P2C {
    # Polar to Cartesian. Convert from AZ,EL to X,Y,Z
    my($AZ, $EL, $X, $Y, $Z) = @_;
    $$Z = sin($EL);
    $$X = -cos($EL) * sin($AZ);
    $$Y = -cos($EL) * cos($AZ);
    return;
sub sgn {
    my($x) = @_;
    if($x < 0) {
        return -1
    elsif($x == 0) {
        return 0;
    else {
        return 1;
sub round {
    my($number) = @_;
    return int($number + .5 * ($number <=> 0));
Re: software (3.00 / 0) (#21)
by david williams on Wed Sep 3rd, 2008 at 11:36:50 AM MST
Yes. It can be tricky to paste program code into a text-oriented system like this one. The system tries to make it look pretty, which may spoil the functioning of the program. Also, things may be wrongly interpreted as commands. For example, in SunAlign I have a variable called TZN (time zone). Some systems take TZN to be a command to switch to italic font, so weird things happen when the program is listed.
If anyone wants a "fresh" copy of the BASIC code for SunAlign, I'll e-mail it to them. Just write to me at:
david.williams@bayman.org
I'm sure you would do the same.
David
Re: software (3.00 / 0) (#22)
by TomW on Wed Sep 3rd, 2008 at 12:55:46 PM MST
david;
I got the last version posted by bills to run on the MacBook I couldn't get the first perl script post to work anywhere but didn't try to debug it far.
Thanks all around.
Re: software (3.00 / 0) (#24)
by bills on Fri Sep 26th, 2008 at 12:40:41 PM MST
Tom, any others, the first version I posted, I posted incorrectly and the backslashes and some other symbols got filtered out. Please only use the second Perl version posted.
Best,
Bill
If the admin wanted to delete the first Perl version I posted it would probably eliminate future confusion.
Re: software (3.00 / 0) (#25)
by TomW on Fri Sep 26th, 2008 at 01:54:50 PM MST
bills;
Thanks for posting the working version. I removed the mangled version per your request.
Re: software (3.00 / 0) (#23)
by david williams on Mon Sep 8th, 2008 at 11:54:59 AM MST
I took a hard look at the BASIC versions of SunAlign above. The QBasic version has weird italic in it, but that may not stop it from working. The generic-BASIC version has somehow acquired a period after every line number. I don't know why the system decided to do that. Unless the periods are removed, the code probably won't work. If you'd like me to send you a copy without any corruptions, just send me an e-mail.
dow
software | 24 comments (24 topical, 0 editorial)
