software | 24 comments (24 topical, editorial)
Re: software (3.00 / 0) (#21)
by david williams on Wed Sep 3rd, 2008 at 11:36:50 AM MST
Yes. It can be tricky to paste program code into a text-oriented system like this one. The system tries to make it look pretty, which may spoil the functioning of the program. Also, things may be wrongly interpreted as commands. For example, in SunAlign I have a variable called TZN (time zone). Some systems take TZN to be a command to switch to italic font, so weird things happen when the program is listed.
If anyone wants a "fresh" copy of the BASIC code for SunAlign, I'll e-mail it to them. Just write to me at:
david.williams@bayman.org
I'm sure you would do the same.
David
Re: software (3.00 / 0) (#22)
by TomW on Wed Sep 3rd, 2008 at 12:55:46 PM MST
david;
I got the last version posted by bills to run on the MacBook I couldn't get the first perl script post to work anywhere but didn't try to debug it far.
Thanks all around.
Re: software (3.00 / 0) (#24)
by bills on Fri Sep 26th, 2008 at 12:40:41 PM MST
Tom, any others, the first version I posted, I posted incorrectly and the backslashes and some other symbols got filtered out. Please only use the second Perl version posted.
Best,
Bill
If the admin wanted to delete the first Perl version I posted it would probably eliminate future confusion.
Re: software (3.00 / 0) (#25)
by TomW on Fri Sep 26th, 2008 at 01:54:50 PM MST
bills;
Thanks for posting the working version. I removed the mangled version per your request.
Re: software (3.00 / 0) (#23)
by david williams on Mon Sep 8th, 2008 at 11:54:59 AM MST
I took a hard look at the BASIC versions of SunAlign above. The QBasic version has weird italic in it, but that may not stop it from working. The generic-BASIC version has somehow acquired a period after every line number. I don't know why the system decided to do that. Unless the periods are removed, the code probably won't work. If you'd like me to send you a copy without any corruptions, just send me an e-mail.
dow
software | 24 comments (24 topical, 0 editorial)
