Leaving freezer on /open | 26 comments (26 topical, editorial)
Re: Leaving freezer on /open (3.00 / 0) (#22)
by JW on Thu Jun 12th, 2008 at 02:09:04 PM MST
Elvin, I remember the R-12 phase-out. Its known that propane can be interchanged in an r12 system. I have done it myself and it does work. Actually I used a mix of 25% isobutane and 75% propane.
 I also found it was slightly more efficient, however I observed this thru reduced compressor loading. A pully size change would have matched temperature as good as r12 im sure. I only charged auto a/c systems.
 As one may use propane based refrigerant, there is a decreased chance of the 'freon' based corrosives, which the dryer normally provides protections for when using r12. Also I saw a couple of refridgerators charged with the propane mix, the oil viscosity had to be reduced to accomodate the alternative freon. but all the systems I observed worked ok for a pretty long time(over 3 years)
 But im pretty sure propane based freon is not allowed, because of the possibilite of a leak developing in such a system charged with that. But it does infact work, interesting that you know that.
 I have never tried this with a system charged with 134a.
JW
Re: Leaving freezer on /open (3.00 / 0) (#23)
by elvin1949 (elvin1949@yahoo.com) on Thu Jun 12th, 2008 at 10:10:55 PM MST
  JW
 The old upright freezer has r12.
So when remaking it into a walkin it has to be converted to something.
 134a is easy to get and propane works better than the 134a and is easier to get.
  JW don't give your age away but when is the last time you saw a Philco-Ford deep freeze.
Elvin
Leaving freezer on /open | 26 comments (26 topical, 0 editorial)
