Leaving freezer on /open | 26 comments (26 topical, editorial)
Re: Leaving freezer on /open (3.00 / 0) (#25)
by getterdone on Mon Jun 16th, 2008 at 09:06:39 PM MST
running the freezer 24/7, the freezer [compressor] will last longer than if it cycles. fact. if the freezer is in the space that your cooling it will generate more heat to the space. heat of compression. energy it takes to run compressor.
suggestion ; you cant dig a celler, a/c units would work in a pinch, but if i am right arnt you supposed to keep wine at a constant temp? buy a lister engine, power a a/c unit off a car. or find an old open type compressor [belt drive] power the thing with used veggy oil.
300 cases of vino you have some money in. if your off grid and need cool storage with out a celler. and are serious about your stash. check into it.
see how the Amish keep things cool.
just my thoughts.
If I were smart I'd be dangerous
Re: Leaving freezer on /open (3.00 / 0) (#26)
by JW1111 on Wed Jun 18th, 2008 at 07:58:57 PM MST
I broke down and bought an ac unit and I have no problem running it off my solar and wind, during the day. Thanks alot. Your advice has been very helpful.
Leaving freezer on /open | 26 comments (26 topical, 0 editorial)
