17' flying - questionable output | 26 comments (26 topical, editorial)
Re: 17' flying - questionable output (3.00 / 0) (#4)
by tecker on Sat Jun 7th, 2008 at 03:25:10 AM MST
Sounds like you need to switch out the Xantrex and go to straight to the batteries to get a good read in to the load .I have to say with the control in there you haven't brought the bank up. The voltage is below cut . Put a charger on the batteries and see if the voltage follows the charger .
Re: 17' flying - questionable output (3.00 / 0) (#5)
by tecker on Sat Jun 7th, 2008 at 03:34:59 AM MST
You may need to setup the Xantrex
17' flying - questionable output | 26 comments (26 topical, 0 editorial)
