Ok cleared my head this am.
Again we have about a 5mph wind - you know it really is true that once you get a wind turbine spinning that you will not have wind! And it is the same forecast for the next week!
Using my meter I checked the voltage from ground to each leg of the 3-phase output from the turbine and each was 24v, which should give me about 33v after the rectifier, so I do not appear to be at cutin speed.
I went back through all my settings on the Xantrex and everything appears to be set correctly.
I think that I may just have to let it wait for more wind...
Dan
