Flat Plate Axial Mill Part 4 | 21 comments (21 topical, editorial)
Re: Flat Plate Axial Mill Part 4 (3.00 / 0) (#5)
by jlt on Mon Jun 9th, 2008 at 07:34:21 AM MST
thats a great looking mill that you are building. I have a few  concerns about it.it should work. but would be better if you heed some advice given by others in the know.but experience is the best teacher. My advice is add some bracing to your tail.and make it have adjustable offset angle i think you will need .more . it will be easy now before it is up on the tower,and painted.
Re: Flat Plate Axial Mill Part 4 (3.00 / 0) (#10)
by brianc4 on Mon Jun 9th, 2008 at 08:32:36 AM MST
jlt,
Thanks for the input. This is my first attempt at a furling tail design and I realize some adjustment may be necessary. The rubber bumpers are a little over an inch thick and have plenty of room to be trimmed down if I need more offset or put some shims behind them if it needs less ofset.
Before the mill goes on its permanent 40' tower at my cabin I will put it up at my shop on a 25' test tower until all the bugs are worked out.
Brian Clark
Flat Plate Axial Mill Part 4 | 21 comments (21 topical, 0 editorial)
