Which charge controller for Yacht PV installation | 8 comments (8 topical, editorial)
Re: Which charge controller for Yacht PV install (3.00 / 0) (#5)
by la7qz on Fri Jun 20th, 2008 at 05:37:28 PM MST
The battery combiner is designed to limit the throughput to 60 A max. It will not pass more than 60A however much is available.
And... the battery banks are well matched.
Owen
Re: Which charge controller for Yacht PV install (3.00 / 0) (#6)
by DamonHD (d@hd.org) on Sat Jun 21st, 2008 at 07:01:52 AM MST
Yes, though it looked like some sort of resistive thing which might get rather warm!
Do you know if they do current limits as low as ~10A on these things, to protect my rather small (40Ah gel) battery?
Re: Which charge controller for Yacht PV install (3.00 / 0) (#7)
by la7qz on Tue Jun 24th, 2008 at 05:27:37 PM MST
Hi
The device I used is this one.
http://bluesea.com/products/7600
I have installed quite a few of them on yachts an not heard of any problems. The cutin point is adjustable and there is also an adjustable overvoltage protection. The unit has terminals for two batteries. In the default configuration it will combine when the voltage on battery A rises above the set cutin point. It can also be configured so that it combines if the voltage on battery A or B goes above the set point.
However, for as small a battery as you are talking about, maybe something like this would be more appropriate:
http://www.xantrex.com/web/id/103/p/1/pt/8/product.asp
On my boat, all charging sources including PV, wind, charger/inverter and the engine alternator are connected to the house battery bank (four Trojan T-105). A Digital Echo charge keeps the engine cranking battery topped up. I also have an 8D gel battery which is going to serve as a dedicated communications battery (ham and marine radios) and I will charge this one with the Blue Sea charging relay in the first link.
Of course, if you have the time to play around with stuff yourself and do not have to rely on these things for your safety out on the big blue ocean, you could use a Ghurd controller to control a big contactor capable of carrying the maximum expected current (and then some).
Owen
Re: Which charge controller for Yacht PV install (3.00 / 0) (#8)
by DamonHD (d@hd.org) on Wed Jun 25th, 2008 at 01:43:58 AM MST
Yes, that looks like the sort of thing I might well use, thank you.
A whole little technology niche that I was ignorant of!
Which charge controller for Yacht PV installation | 8 comments (8 topical, 0 editorial)
