Cheating local zoning laws with a VAWT | 18 comments (18 topical, editorial)
new-to-welding tip (3.00 / 0) (#10)
by spinningmagnets (velmis1450bc(at)aol(dot)com) on Sun Aug 3rd, 2008 at 01:11:36 PM MST
You probably already know this, so I'm not trying to insult you, but...
If you are new to welding, don't think you can whip out a quick job by squinting your eyes, while you plan on getting a face shield/dark goggles later.
Also, I highly recommend you practice on some scrap. If you are already experienced at welding, I apologize for any assumptions.
Re: new-to-welding tip (3.00 / 0) (#11)
by Todd a on Tue Aug 5th, 2008 at 05:06:20 PM MST
It has been MANY years since I welded.  Yes I use a welding mask... my neighbor thinks sun glasses are fine.  The sun burn he got was pretty bad.  I took 3 years of metals in school and the last year was about 80% arc welding.  Yes that was over 20 years ago.  I do not have much in the way of scrap, so I started in a less important location (the cylindar the shaft mounts to.  It took a bit to get used to the welder, but everything worked out.  I got about half the welding done and it might not be as nice as I used to do it is more than functional enough.  I have tomorrow off work so I should be able to finish up the rest of the welding, touch it up with my angle grinder, and get it painted.  If I have time I will assemble the generator and finish the wiring.
Cheating local zoning laws with a VAWT | 18 comments (18 topical, 0 editorial)
