i made a mistake | 8 comments (8 topical, editorial)
Re: i made a mistake (3.00 / 0) (#1)
by windy on Wed Jul 16th, 2008 at 09:05:53 PM MST
blueyonder
The best teacher is the mistakes we all make. Glad to hear you got it repaired!
windy
Re: i made a mistake (3.00 / 0) (#2)
by Flux on Thu Jul 17th, 2008 at 12:55:01 AM MST
Always check first before potting. As I read through this I guessed that you had reversed at least some of the magnets, that is about the only thing that would cause the leakage.
I am pleased that you managed to rescue the situation, that is one mistake you will not make again.
One of those things that comes with experience. I have several easy methods to make sure I don't do this but I deal with magnets daily for other reasons. I find the simplest method apart from the fluxmeters and search coils is to hold a decent sized neo magnet in the fist and pass it over the mounted magnets to see that it alternately attracts and repels. As long as you have the thickness of your fingers between the test magnet and the rotor you are checking it is perfectly safe, but even so I suspect someone not understanding exactly what to do could screw it up and hurt themselves so use your own discretion.
i made a mistake | 8 comments (8 topical, 0 editorial)
