For running the pond fountain, a simple voltage sensor (eg a zener diode driving a transistor/relay combo) to turn on the pump when the shed batteries reach full charge or maybe monitor at the genny so that if the voltage rises significantly due to a high charge current then the extra load is turned on (using the pump as a dump load in effect!!) Robin - Down Under (or are you Up Over)
Any circuit references to to achieve : " For running the pond fountain, a simple voltage sensor (eg a zener diode driving a transistor/relay combo) to turn on the pump when the shed batteries reach full charge or maybe monitor at the genny so that if the voltage rises significantly due to a high charge current then the extra load is turned on (using the pump as a dump load in effect!!)"
Thanks and enjoy the paradise. -> No is not the answer. Just a challenge. <-[ Parent ]
I use my main Internet server/laptop as a dump load, see:
http://www.earth.org.uk/low-voltage-drop-out-circuit-design.html
This involves an LVD with higher-than-usual voltage thresholds to only divert power to the laptop when the battery is pretty full and being charged and I also have some monitoring and software tweaks on the laptop to ramp up power consumption further if the voltage continues to rise. This makes a variable dump-load of between about 20W to 60W for my small system.
Damon[ Parent ]
Then all you have to do is adjust the resistor values for the voltages you want. Easy.
Adding a diode drop means the shed batteries will never achieve full charge. Meanwhile the house batteries will require a dump load that goes on even if the shed batteries aren't yet fully charged.[ Parent ]
the way the site is organized :
WindMill ^ | 20 metres. | [House ] ^ | 10 metres <--------50 metres------->[ pond] | | | 40 metres < ------40 metres-------->[cattle shed]
AC to DC conversion is done at the batteries location.
Not a very good site design above but should be enough to give some idea. Overall capacity of generation is much above what I need so keeping some lights for cattle all the time doesn't seem to hurt me... I need to watch the results over next few days.
Thanks for the inputs. -> No is not the answer. Just a challenge. <-[ Parent ]
