Cheap dump load | 7 comments (7 topical, editorial)
Re: Cheap dump load (3.00 / 0) (#7)
by frackers (g8ecj at *nospam* gilks dot org) on Mon Jul 21st, 2008 at 05:54:09 PM MST
Seems like it was one and a half hours well spent :-) And all scrap materials - even the nails were reclaimed from a bunch of pallets!
It will be on a 24volt system so I expect that I'll only run it up to about 35volts (i.e. without a battery bank, just the genny on the PTO) where the full length will be dissipating 650watts (35^2 / 1.88).
For higher current tests where I want to load the genny to about 40amps at 28volts (max design charge current on a fully charged bank) the 1120watts will be spread over about a third (0.7 ohms for that load of course) of the wire length so I expect it will cook then - so long as the smoke isn't the magic variety that makes all the electrons go round I think I'll be OK...
Cheap dump load | 7 comments (7 topical, 0 editorial)
