small LENZ 2 with bicylce hub dynamo | 6 comments (6 topical, editorial)
Re: small LENZ 2 with bicylce hub dynamo (3.00 / 0) (#1)
by electrondady1 on Fri Jul 25th, 2008 at 07:11:42 AM MST
perhaps ed will respond
i think it would be prudent to physically test the alternator at specific speeds.
at the relatively low rpm of a vawt it's possible
 i use a musical metronome
you can adjust the beats per minute(rpm)
then turn the alt in sync and observe the output .
when you put an electrical load on the alternator the speed of the mill will be reduced.
if it is reduced to the point were the alternator is no longer producing a usable  voltage you will need increased height.
Re: small LENZ 2 with bicylce hub dynamo (3.00 / 0) (#2)
by marquee moon on Fri Jul 25th, 2008 at 07:45:07 AM MST
thanks, I'll give the metronome idea a go. when you use a metronome, do you hand crank the motor? (I can imagine that at higher revs this may get fun...)
small LENZ 2 with bicylce hub dynamo | 6 comments (6 topical, 0 editorial)
