refrigerant driven turbine ? | 13 comments (13 topical, editorial)
Re: refrigerant driven turbine ? (3.00 / 0) (#1)
by spinningmagnets (velmis1450bc(at)aol(dot)com) on Fri Jul 25th, 2008 at 03:00:41 PM MST
Read this:
http://www.fieldlines.com/story/2008/2/4/0350/64735
As wdyasq informed me, this would be a Rankine cycle engine, like a steam engine with a working fluid different than water.
I also recall a Do-It-Yourself (DIY) "Belize Butane engine" You might Google it to get some small scale ideas.
Best of luck. -Ron in 105F SoUtah
"Most people miss opportunities because it often comes dressed in overalls, and looks suspiciously like work" -Edison
Re: refrigerant driven turbine ? (3.00 / 0) (#2)
by remember (sweetwaterwellservice@frontiernet.net) on Fri Jul 25th, 2008 at 09:39:14 PM MST
This is close to what you are describing, no?
http://www.popularmechanics.com/science/earth/4232571.html
Re: refrigerant driven turbine ? (3.00 / 0) (#3)
by remember (sweetwaterwellservice@frontiernet.net) on Fri Jul 25th, 2008 at 09:53:36 PM MST
Oops, same article you referenced.  They used a car power steering pump running "backwards" as a turbine.  Got about nine percent of energy collected out as electric, the rest as heat. Haven't tried it yet but am building a collector.
Re: refrigerant driven turbine ? (3.00 / 0) (#5)
by petect on Sat Jul 26th, 2008 at 10:00:05 AM MST
That's the idea. I just need to scale it down.
Pete
refrigerant driven turbine ? | 13 comments (13 topical, 0 editorial)
