Battery Bank Fuse | 15 comments (15 topical, editorial)
Re: Battery Bank Fuse (3.00 / 0) (#10)
by wpowokal on Sun Jul 27th, 2008 at 06:37:46 PM MST
Roger you are correct although not too many people want to know, it would cost them more.
And while we are about it fuses and switches have AC & or DC ratings because DC is harder to interupt than AC.
Ac swings between positive and negative each cycle passing through zero volts, which makes breaking an arc more achievable. DC has no zero crossing point and the arc may contiue across a gap if the fault is severe enough.
allan down under
Battery Bank Fuse | 15 comments (15 topical, 0 editorial)
