Battery Bank Fuse | 15 comments (15 topical, editorial)
Re: Battery Bank Fuse (3.00 / 0) (#2)
by frackers (g8ecj at *nospam* gilks dot org) on Sun Jul 27th, 2008 at 06:11:04 AM MST
For any appliance that has a motor in it expect to see a current surge at startup of about 6 times the normal current. If the washing machine motor is rated at say 300watts (I think mine is actually over 1500 but lets stick with this example) then the peak power will be 300 * 6 = 1800 watts. Now the current to give 1800watts at 12volts is 1800 / 12 which gives 150amps. That would be the fuse rating.
This gives rise to another question though - can your inverter supply the surge that the motor startup will require. That depends entirely on its specs and of course the rating of the motor in the washing machine in the first place!!
If your inverter is really limited to 1000watts then the fuse should be spec'ed to suit it i.e. 1000 / 12 = 83.3 amps. Rounding up to the nearest likely value (since a fuse should be protecting only a fault condition) then you should be good to go with 100amp fuse.
Battery Bank Fuse | 15 comments (15 topical, 0 editorial)
