Yes, with 30 magnets and 90 coils it would be based on 3 single phase windings each with one coil per magnet. The 3 windings will be displaced 120 degrees electrically to produce 3 phase.
We only need to consider the single phase case here so a full winding would have 30 coils and because each alternate coil was covered with a magnet of different polarity you would need to reverse alternate coils ( SFFS etc).
If you remove half the coils and leave 15 all over the same magnet polarity it still works ok and the coils remaining are connected in series without reversal ( NSNS etc). You can increase the turns to compensate the voltage and you have the extra winding space to use thicker wire.
If this is a closed iron circuit ( which it is)and you feed a dc current into the winding you will have identical poles over the centres of the coils. The flux has to complete the path and it will return via the spaces between the poles produced. There will be consequent or phantom poles formed between the poles at the centre of the coils and it will behave exactly as a 30 pole winding although you have 15 coils.
Both winding schemes are used commonly, N.America tends to favour the consequent pole winding while Europe probably has more small machines wound with full coil in a 2 layer winding. There is negligible difference and often rewind companies will change the method to suit their facilities. For hand winding many go for the consequent winding, whereas those with winding formers may go for the 2 layer winding where all coils are the same.
