New Battery Technologies | 11 comments (11 topical, editorial)
Re: New Battery Technologies (3.00 / 0) (#9)
by wdyasq on Thu Jul 31st, 2008 at 07:55:55 AM MST
JW,
To make things simple take your Voltage X Amperage and you will get Watts. In our 'amperage' figure there is a time, the hour, so our final figure is in Watt Hours.
12V X 255AH = 3060Wh or, converting to kWh, 3.06kWh at 100% discharge.
Now note if we had worked with 6V Batteries it would have been 6V X 255AH = 1530WH and we would have needed to multiply by the umber of batteries (2) and we end up at the same place.
The 'real' way to calculate power is a lot more interesting and involves a bit of higher math than we want to go into here. It also yields similar results. The power in the bank is the number of batteries X the capacity of each battery.
Don't forget, that is at 100% discharge. The figures need to be lowered for any practical application.
New Battery Technologies | 11 comments (11 topical, 0 editorial)
