3 Blades vs 2 | 10 comments (10 topical, editorial)
Re: 3 Blades vs 2 (3.00 / 0) (#3)
by rpcancun (hobbyshopmx@hotmail.com) on Wed Jul 30th, 2008 at 12:54:20 AM MST
thx flux..last night we had some good wind and the blades where whippin good,..but the yaw torque i saw made me nervous it was jammin, im thinking maybe gear it 2-1 so the blades can stay slow, if they need more torque i could widen the blades to 2 foot wide and adjust the pitch control not to run too fast,..that would lessen the yaw torque i saw last nite..
thx for your input.....
Rob
Re: 3 Blades vs 2 (3.00 / 0) (#4)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Wed Jul 30th, 2008 at 06:16:17 AM MST
remember that when you connect your generator to the blades and start charging a battery. there will be magnetic drag forces that will control the speed of your blades
W o o f -={(
Re: 3 Blades vs 2 (3.00 / 0) (#5)
by Flux on Wed Jul 30th, 2008 at 08:16:40 AM MST
Not sure what you mean by yaw torque. You seem to be afraid of speed, I don't have all the alternator information but it looks as though it is slow for 48v, if you say that you got 6 to 8v in low wind then it must have been crawling round.
Adding gearing and increasing torque by widening blades would let you run with very low speed indeed, but the extra mass of the blades will most likely give your pitch mechanism and blade roots far more stress than if you went for a reasonable speed prop with direct drive.
Pitch control mechanisms are excellent if well designed, but in the hands of the inexperienced I think there is much more chance of failure than with simple carved wooden props. Most of these can survive very high speeds and if you keep the load on them they rarely fail. I haven't seen drawings of your pitch mechanism but some of the ideas I see far from inspire me and a windmill is the best fatigue testing thing available.
Re: 3 Blades vs 2 (3.00 / 0) (#8)
by rpcancun (hobbyshopmx@hotmail.com) on Wed Jul 30th, 2008 at 12:37:54 PM MST
http://www.fieldlines.com/story/2008/7/25/173638/133
Theres some pics of the pitch control there...
Guess ill try making the planks into airfoils (clark Y)
What I meant by yaw torque, is that when its going fast and the tail moves
it really seems to slam the tower kinda like a rattle because the blades are moving faster and they don't seem to like the sudden change in direction,...maybe i should video it next time and put it on you tube maybe i can get some better input...
Thx
Rob
Re: 3 Blades vs 2 (3.00 / 0) (#9)
by Flux on Wed Jul 30th, 2008 at 01:06:07 PM MST
Thanks for the pictures. I can't see any method of synchronising the two blades but I may not have got the whole picture.
I can certainly see why you are afraid to let it reach any speed.
The shudder during yaw is inherent with 2 blades. If the site is clean and it yaws slowly it may be reasonable but if there is any turbulence it will shake like crazy.
You have a lot of mass and inertia in a heavy prop of that size. Ideally if the pitch mechanism was perfect you could damp the tail movement to slow the yaw and reduce the judder. I have not used 2 blade props above 8ft and with reasonably light wooden blades the problem is acceptable but I wouldn't want to go much bigger.
Pitch control is nice but it is really a refinement. It should be based on 3 blades if at all possible.
I am sure making your blades something close to Clark Y will improve the speed and output immensely and if you can reduce the mass, especially at the outer radius I don't think the yaw judder will be worse than with the heavy planks at lower speed. Whether you can live with a 2 blade machine at that diameter depends on your nerve and the local wind conditions.
Re: 3 Blades vs 2 (3.00 / 0) (#6)
by wdyasq on Wed Jul 30th, 2008 at 09:05:50 AM MST
Rob,
The dynamics of rotating 2 blades Vs 3 Blades has been known since before WWII. It can be explained. I doubt it can be explained to those ignorant of apparent wind, angle of attack, stall, lift, negative lift, centripetal force and furling in less than a small book. Some reading this, perhaps most, will be ignorant in one or more of those fields. But, by WWII, manufacturers of airplanes figured out 2 blade propped large planes would tear up stuff and placing a 3 blade prop on would cure some of those problems.
There have been many attempts to build Variable Pitch wind turbines. Some time back "Dinges' and I put together all of the VP patents we could find in one repository:
http://www.anotherpower.com/gallery/Variable-Pitch
Jacobs, the accepted master of the art, admitted having problems with larger sizes in his later patents. If one were attempting to build a new VP system, they would be well served to study what is in the patents.
3 Blades vs 2 | 10 comments (10 topical, 0 editorial)
