$4 Trojan T-125s ?! | 23 comments (23 topical, editorial)
Re: $4 Trojan T-125s ?! (3.00 / 0) (#20)
by JW on Tue Aug 5th, 2008 at 09:32:13 AM MST
One thing that could explain that, is that they were topped off at some point, using tap or well water, this would add a contaminate, such as minerals from the water. Only add distilled water to them.
 You may be able to replace the electrolite with store bought electrolite. This is found at the auto parts store, generally packaged in a cardboard box with a bag inside to hold the electrolite. This may, or may not work, depends. If you go that route, use only distilled water to flush the sediment.
JW
Re: $4 Trojan T-125s ?! (3.00 / 0) (#21)
by elt on Wed Aug 6th, 2008 at 08:02:40 AM MST
Thanks JW,
I got 5 gallons at a battery store for $13 USD. (I figured that if I did all eight batteries then I'd need about 3 gallons.)
I did two pair yesterday. The sludge at the bottom is so heavy that it doesn't readily come out. After two gallons and six rinses, it was still coming out so I had to say "better is good enough" and put in the new electrolyte.
That leaves me wondering this: that pair was one of the second set where the water was way below the plates so I'm assuming that they are sulfated. So if I desulfate them, won't the SG go through the roof? ... I'll be monitoring the SG regularly to see if that happens.
Thanks again,
 - Ed.
$4 Trojan T-125s ?! | 23 comments (23 topical, 0 editorial)
