I am pretty sure with motors that size (0.58A), the PWM isn't worth the effort. At best, the fan above saved a hair under 25% at low speed. Much less savings at higher speeds. Myself, I'll stick with simple power resistors until the motor is quite a bit more powerfull, maybe 3A?
Samoa's circuit is easy to build. Works fine with the changes I told my friend to make (Schottky Flyback, and better mosfet).
You can build a "regulated" transformer. Same as what you had, but a bigger cap. Then feed the output to a low drop-out 7812 (TO-3 size, with heat sink), and a small cap and 1M resistor across the final output. It is not efficient. I wouldn't do it for a motor. Really, a "12V" motor should handle 16V no problem.
G-[ Parent ]
