Question on three sided tower tilt over base | 6 comments (6 topical, editorial)
Re: Question on three sided tower tilt over base (3.00 / 0) (#3)
by dynaman on Sat Aug 2nd, 2008 at 10:48:16 AM MST
Here is  shot of the hinge I made for my tower. It works quite well. The only downfall of the three sided tower is that because there are only three anchor points the back guylines go slack as the tower goes down therefore there is a potential for the tower to exert tremendous twisting  force on the hinge should it catch a breeze or such. I install temporary guys inline with the hinge when I am going to lower the tower so that the tower cannot swing and damage the hinge.
Re: Question on three sided tower tilt over base (3.00 / 0) (#4)
by elt on Sat Aug 2nd, 2008 at 01:57:19 PM MST
Thanks dynaman, I saw your 12' project in your diary... very nice!
Do you clamp the two sections of your hinge together or just let the guy wires hold it in place?
What's the diameter of the rod you use as the hinge pin?
I thought of that; I think that having a rigid separator between the two legs being hinged make a lot of sense but the manufactures tilt up base (for my tower) is very minimalistic. Here's a pic from the catalog -
While that design leaves me a little uneasy, I'm still wondering if there's a benefit of support the third (non-hinged) side of the tower during tilt up.
Hm... since three complete sets of guy wires are cheaper than four, makes me wonder why folks with the pipe towers don't use three sets?
Thanks again,
 - Ed.
Question on three sided tower tilt over base | 6 comments (6 topical, 0 editorial)
