Another UPS question | 11 comments (11 topical, editorial)
Re: Another UPS question (3.00 / 0) (#10)
by domwild (domwild at hotmail dot com) on Mon Aug 18th, 2008 at 05:01:01 AM MST
Here is my 2c worth:
  1. Your UPS may not cold-start. Hook it up to mains, switch mains off, then it may start. From memory, switch DC on first, then mains.
  2. UPS as inverter - you may have to add on an extra fan from a PC CPU or PSU to cool the heatsink where the FETs are sitting on as the UPSs are designed for only a short-time AC delivery.
  3. If you are using batteries other then the common SLAs, which come with the UPS in a separate box, then remember, an SLA is being charged at a slightly lower terminal voltage. Something I found out by using large car batteries instead.
Good luck!
Another UPS question | 11 comments (11 topical, 0 editorial)
