TDM Genny in progress | 6 comments (6 topical, editorial)
Re: TDM Genny in progress (3.00 / 0) (#1)
by wdyasq on Tue Aug 12th, 2008 at 05:29:06 PM MST
Vic,
Other than the butt-weld which has been commented on and lack of bracing on it it looks good. If you can get enough speed for charging with the Ametek with 6 blades you will be one of the few.
With as much investment as you will have in tower it will be beneficial for you to think of a bit more 'mill'. A 'DanBuilt' style axial or a motor conversion will proove to be less trouble and put out more energy than the Ametek.
Re: TDM Genny in progress (3.00 / 0) (#2)
by vfarrell on Tue Aug 12th, 2008 at 10:07:00 PM MST
"If you can get enough speed for charging with the Ametek with 6 blades you will be one of the few."
yeah I might want to change out the blades to a larger 3 blade configuration , Was looking for more tork.
"With as much investment as you will have in tower it will be beneficial for you to think of a bit more 'mill'. A 'DanBuilt' style axial or a motor conversion will proove to be less trouble and put out more energy than the Ametek."
I see your point, maybe I can start winding some coils this winter if time permits however I already have the tower x 2 so the investment is minimal..
Thanks for the feedback
"Everybody's got to believe in something. I believe I'll have another beer." --W. C. Fields
Re: TDM Genny in progress (3.00 / 0) (#3)
by hiker (hiker.wild[at]yahoo[dot]com) on Sun Aug 17th, 2008 at 12:53:14 AM MST
looks great...
but does it furl okay.....
looks like its mounted to close to the post....
WILD IN ALASKA
Re: TDM Genny in progress (3.00 / 0) (#5)
by vfarrell on Sun Aug 17th, 2008 at 08:00:04 AM MST
furl great ,, it have a nice balance as well, however prob won't repeat that design again and was for TDM only,,lol it set on the shelf for a long time while while other projects had to be completed were taken care of..  The guys here have a well proven design that will hold up to about anything.
 Once the tower is up I'll fly this one for awhile then probably change over to a better, more robust design like the danbuilt..
TDM Genny in progress | 6 comments (6 topical, 0 editorial)
