The batteries have arrived as promised - the supplier took the half dozen recycled truck batteries that I'd finished off in exchange for the delivery charge - he's happy and so am I :-)
They are all sitting, fully charged, at 6.39 to 6.41 volts so I'm going to set my dump load voltage to 6.75 volts per battery (27 volts rather than the 28 I was going to use). On the discharge side of the equation, I'm again going to err on the side of caution and cut out at 23 volts. I'll keep an eye on the specific gravity over a few days/weeks and see what happens.
Thanks for confirming my suspicion that I can't really use voltage, especially if charging at a high current. Guess I'll have to build the proper charge monitor/load-controller by counting amp-hours in and out of the battery bank. Got most of the bits, I've just got to clear the decks of all the other projects which may take a while with spring just round the corner!!
