How many watts are in 22000kwh? [CLOSED] | 11 comments (11 topical, editorial)
Re: How many watts are in 22000kwh? (3.00 / 0) (#1)
by kurt on Fri Aug 15th, 2008 at 03:10:10 PM MST
NO NO NO!! 1 KWH = 1000 watt hours if you plugged in 10, 100 watt light bulbs and left them on for an hour they will have consumed 1 kWh of electricity watts is how much power a device uses at any given time (amps*volts). watt hour or KWH is energy used over time...
http://www.reresource.org/
IRC
Re: How many watts are in 22000kwh? (3.00 / 0) (#2)
by Focus on Fri Aug 15th, 2008 at 03:44:00 PM MST
That web page doesn't come up.
So how many wats do I need to make to cover 22,000kwh then?
Focus, it only hurts for a minute...
Re: How many watts are in 22000kwh? (3.00 / 0) (#3)
by TomW on Fri Aug 15th, 2008 at 04:48:58 PM MST
focus;
I might suggest that you focus on what he said. He gave all the info you need to get you started on a plan. You need other info besides what you need in KWH.
Your question really has no answer unless you have more information to offer on exactly what you are trying to accomplish [in detail].
Might be a good idea to do some reading.
That web page is his signature, not the answer to your question.
Some folks should just give money to the pros to get it done. You will need to spend a tad more effort to save that 150 grand beyond posing the question here.
You might think this is mean or nasty but the stone cold fact is you provide nowhere near enough information to get a useful answer.
None of this is rocket science but it is a bit technical and your initial post shows you need more knowledge of electrical power and energy in general.
Good luck figuring it out.
How many watts are in 22000kwh? [CLOSED] | 11 comments (11 topical, 0 editorial)
