kollmogen 24 volt brushless 450 watt as 3 phase generator | 1 comment (1 topical, editorial)
Re: kollmogen 24 volt brushless 450 watt as 3 phas (3.00 / 0) (#1)
by Flux on Sun Aug 17th, 2008 at 03:34:54 PM MST
It's too small and too high speed to even consider for a Savonious. Yes you can get the speed down if you use thin enough wire but you will only have a few watts out at the end. Never worth the trouble.
kollmogen 24 volt brushless 450 watt as 3 phase generator | 1 comment (1 topical, 0 editorial)
