Inverter as dump load | 10 comments (10 topical, editorial)
Re: Inverter as dump load (3.00 / 0) (#5)
by ruairihev on Mon Aug 18th, 2008 at 10:16:03 AM MST
Thanks for the comments,
I realise now that I shouldn't have titled the post 'Inverter as dump load' but something more like 'Using an inverter to dump load'.
The LVD is a good idea that I will employ, also I think I will use SSR's as the relays will probably not last too long.
I had thought about direct connection but the controller side of it seemed difficult so I said I'd take the easier option in my opinion and use the AC side controlled inverter. If I feel brave in the future then I will try a direct connected heating wind turbine.
I know the answer to this but I need someone to tell me that in the long run its better to buy the pure sine wave inverter than the cheap MSW inverter? Its a difference of €250 versus €1000. But because its only being used for resistive elements the MSW might do the trick?
Re: Inverter as dump load (3.00 / 0) (#6)
by ghurd on Mon Aug 18th, 2008 at 10:30:29 AM MST
I think MSW would be fine for this.
Not sure 3000W is needed is the max load is 1500W.
I would probably go with a 1500W or 1750W.
If the windmill is 1KW, then dumping 1500W would be a rarity I think.
I might even change the 500W element to 250W.  Max load would be 1250W, then a 1500W inverter should handle it.  Here, about 1500W is where inverters start to get expensive faster, in $/W.  The savings may buy a TriStar?
Re: Inverter as dump load (3.00 / 0) (#7)
by Flux on Mon Aug 18th, 2008 at 10:46:45 AM MST
I agree with Ghurd completely. Sine wave inverter would be wasted for resistive load.In most cases the efficiency of pure sine is lower unless you pay a fortune.
Choose your load correctly and a 1500W inverter should do the job easily.
Re: Inverter as dump load (3.00 / 0) (#10)
by ghurd on Tue Aug 19th, 2008 at 07:44:55 AM MST
For the LVD,
If the inverter has a regular rocker switch, then a small regular 24V relay with a high ohm coil can be paralleled with the switch.
The LVD will basically turn the switch (relay) off.  No need to deal with large amps in the cables.
(same idea as Speo's 'remote control inverter')
http://www.fieldlines.com/story/2008/4/11/5115/12104
Inverter as dump load | 10 comments (10 topical, 0 editorial)
