Inverter as dump load | 10 comments (10 topical, editorial)
Re: Inverter as dump load (3.00 / 0) (#8)
by frackers (g8ecj at *nospam* gilks dot org) on Mon Aug 18th, 2008 at 04:35:08 PM MST
Sounds like you are going down the same path as I did - and my system is still running even if its a mains voltage heater and not the pool pump yet (gotta run the cables!!)
Check out my logic for this way of doing things here
Inverter as dump load | 10 comments (10 topical, 0 editorial)
