Your Grandfather's Micro-Hydro | 15 comments (15 topical, 0 editorial)
Re: Your Grandfather's Micro-Hydro (3.00 / 0) (#5)
by TheCasualTraveler (a.miklos@yahoo.com) on Mon Aug 18th, 2008 at 05:35:10 PM MST
I just realized I didn't give you the specs.
     The wheel is 12 foot diameter. On the same shaft as the wheel is a gear, 48 inches diameter. From that gear runs a chain to a smaller 6 inch gear. On the same shaft as that 6 inch gear (inside the shroud) is another 48 inch gear and from that gear runs a chain that turns another 6 inch gear on the generator.
Andy
