Front Page
[Homebrewed Electricity
(wind)
(solar)
(hydro)
(steam)
(controls)
(storage)
(mechanical)
Classifieds
Site News
Everything
Newbies
[Remote Living
(housing)
(heat)
(light)
(water)
Rants & Opinion
Diaries
Our Products
Problem with inverter
7
comments (7 topical, editorial)
Re: Problem with inverter
3.00 / 0
#7
by Opera House on Tue Aug 19th, 2008 at 02:41:11 AM MST
User Info
I buy defective inverters and repair them. Usually when the output shorts, they go into a safe shutdown. Here is an easy way to check the FETs. Use a digital ohm meter and measure resistance between the two outside legs of the FET. Under a couple ohms is a defective FET. These generally have about a 100 ohm resistor isolating the gates of parallel FETs. The gate almost always shorts in a failure. In the H bridge output, the defective FET can be just wiggled till the leads break. Generally two fail at a time. You can now use this no solder repair at half the rated power. Failure on the multiple boost inverters can be trickier. A short on these FETs can often take out the gate driver transistors.
7
comments (7 topical, 0 editorial)
create account
How to use the board
FAQs
search the board
Google search the board
Old Otherpower Board
