The mill is up and running | 17 comments (17 topical, editorial)
Re: The mill is up and running (3.00 / 0) (#12)
by CmeBREW (smke833f@hotmail.com) on Fri Aug 22nd, 2008 at 08:19:11 PM MST
Yup, 4ft diameter and more speed (400-1000+rpm) seems best for the Ameteks.
For me, I would say that a 6' diameter is usually around 200-700rpm for a common power producing range. But it can vary some with different mills and blades.
You can still see your 6' diam. set of blades go above 400rpm with the Ametek in a fairly big wind  and begin charging your battery if you wish. (maybe upto 40watts??)
But you would be missing the best power producing 'curve' (power producing rpm range)for that particular motor if you stayed with the 6ft.
You can keep the 6' blades for a bigger dc motor or better yet, a homemade alternator later on which is most efficient.
-Let us know how it goes.
The mill is up and running | 17 comments (17 topical, 0 editorial)
