The mill is up and running | 17 comments (17 topical, 0 editorial)
Re: The mill is up and running (3.00 / 0) (#16)
by TomW on Sat Aug 23rd, 2008 at 07:56:11 AM MST
bend;
I am not tracking you at all. Maybe its me, but your terminology is a bit non standard.
To me, if I put a component [your diode] "across" another component [your generator]it means it is in parallel with the other component.
If you put a diode "across" leads on the generator it is a half wave short. This may appear to work into a resistance but I assure you it is not working "right"
Just trying to understand. Maybe pop into IRC where these things get sorted quickly.
Re: The mill is up and running (3.00 / 0) (#17)
by bend1 on Sat Aug 23rd, 2008 at 10:54:26 AM MST
It is connected between the positive wire of the mill and the other side is connected to the terminal block that goes to the battery it is a (blocking diode)allowing the voltage/current of the mill to pass to the battery but not allow the batttery voltage/current to flow to the mill and power it.
