Finally starting plans on a new genny! | 16 comments (16 topical, editorial)
Re: Finally starting plans on a new genny! (3.00 / 0) (#12)
by Jeff (ruralmcguyver at yahoo dot com) on Sat Aug 9th, 2008 at 10:18:11 AM MST
Did I mention the 48 1 x 1 x 1/4 ones I can get in N48? For all 96 (inner & outer)the set is only $120!!! But after drawing the thing up, I realized where you may be coming from. With the 2x1x1/2 ones mounted long-ways on the ID, it takes 24 of them. I can get them in N45 here for about $100.
http://www.magnet4less.com/product_info.php?products_id=62
Then, if it doesn't produce enough with just the "single rotor", I could always add the inner rotor later. Just as a single rotor though, I'd have twice as many mags as most radials do. THEN, If the thing works half-way decent at all, I should put out some serious power! For the size & construction though, it would always be limited to not much more than 300rpm.
Mark: You'll have to explain a little more about the band w/no mags. Yes, my email is working. ruralmcguyver at yahoo dot com
I am able to manage all my electric needs (and then some) with a steady 3amps input into my battery bank. I have 6 12v 115amp/hr batteries now!!! This isn't counting what I'm getting from my 45watt H.F. solar panels. So...I figure the 5amp figure I was shooting for with this gennie was a good-safe goal.
I appreciate all your help on this. Even though I enjoy doing this kind of thing, it is kind of a 1-shot deal, at least for a year or so. So it's not like if the mags I buy don't work, I can set them aside to use on another project & buy some more.
For now, it looks like the 1x2x1/2 ones are pretty sure. If I do have to add the inner rotor though, it'll take me another year to save up for them.
Thanks again everyone!
Rural McG
Re: Finally starting plans on a new genny! (3.00 / 0) (#13)
by vawtman (vawtman(at)charter(dot)net) on Sat Aug 9th, 2008 at 12:14:49 PM MST
Oops your mags were wider so the 1x2s would be 36pl for that diameter in my opinion.
Re: Finally starting plans on a new genny! (3.00 / 0) (#14)
by Jeff (ruralmcguyver at yahoo dot com) on Sat Aug 9th, 2008 at 04:02:14 PM MST
36 Places???
i WENT BACK TO THE DRAWING BOARD. Crap! sorry about the caps! Anyway, it looks like 24 mags on the I.D. of the larger 19 3/8 pan. I still think this may be the best setup for me. As long as I cross my fingers and get 3-5 amps out with just the "single rotor" config., the future addition of an inner rotor would be gravy. Here's a pic:
http://www.otherpower.com/images/scimages/9063/Generator_v1C_24_Mags_Main_View.jpg
I left the 0.3inch gap between the mags because of the smallest gap on the future possibility of an inner rotor. Obviously the dimensions of a coil will have to be made to match up with an exact coil/mag config with every 3rd coil.
Thanks again!
Rural McG
Finally starting plans on a new genny! | 16 comments (16 topical, 0 editorial)
