A close call! | 12 comments (12 topical, editorial)
Re: A close call! (3.00 / 0) (#5)
by tecker on Sat Aug 2nd, 2008 at 09:05:47 AM MST
There's no substitute for soldered ring lugs and screw down connectors for things you want to disconnect at some point solder them to be sure (moisture)
Re: A close call! (3.00 / 0) (#6)
by TomW on Sat Aug 2nd, 2008 at 10:11:14 AM MST
tecker;
I would add that it is a good idea to use "OX-Gard" or other similar treatment for these screw terminal connections. Keep the air out and the connection clean. Often used for dissimilar metals in one connection. I use it on all screw type clamp connections inside or out. Just to be sure corrosion doesn't get a toehold.
Re: A close call! (3.00 / 0) (#10)
by tecker on Sun Aug 3rd, 2008 at 11:11:11 AM MST
I like Oxguard I've used carbon grease and it works good but it migrates and oxguard doesn't  the oxguard kinda scabs over for a nice moisture barrier
A close call! | 12 comments (12 topical, 0 editorial)
