Low power output, 24 pole 3 phase alternator | 11 comments (11 topical, editorial)
Re: Low power output, 24 pole 3 phase alternator (3.00 / 0) (#11)
by rfirth (rfirth1@(remove this part)lsu.edu) on Thu Aug 21st, 2008 at 08:04:41 AM MST
That's what I thought as well, although it sounds like I could get away with fewer turns of wire and still get the required voltage. Nonetheless, I'll be getting better wire. Am I right to be aiming for less than 1 ohm for an entire phase (across all 6 coils)? That should be reachable if I can get the coils to fit. Seems if I could get 14 times less resistence with heavier wire, use a few less turns, and get my iron magnetic flux plates worked out, that output should be increase substaintially.
Robert Firth
Low power output, 24 pole 3 phase alternator | 11 comments (11 topical, 0 editorial)
